3 members (DES57, 2-Ton, 1 invisible),
102
Mod | | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Is there a way to make a foot start work like it did when my suburban was a 216 3sp 6V if so what parts do i need Thanks Tony | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Add a switch in the floor. Wire the starter so that when yhou press the switch in the floor it activates the starter. But it doesn't look or act much like the original floor starter.
You can mount this switch where the old starter mechanism came through the floor. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Seems to me that if the bellhousing you are using was set up to hold the foot starter mechanism, all you would have to do is put the foot starter back on, and use a 6v starter with switch as per original. Might need to change the flywheel or pinion gear of the starter to match. The 6 volt starter will work fine.
Alternatively, You could use the foot starter mechanism to hit or work a switch which will activated the starter solenoid. This should be pretty easy to do.
Kurt | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The 292 will not accept the 235/261 starter- - -the bellhousing and flywheel setup is totally different. You can fabricate a fake foot start that will resemble the original pedal inside the cab with a little ingeneuity- - -just make a spring-loaded pedal that brackets to the floor in the original position, and put a push button switch under it to activate the solenoid. If you use the original pedal and rubber boot, the difference won't be noticeable to anyone without opening the hood and looking for the mechanical linkage to the starter. Jerry
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | The 292 will not accept the 235/261 starter- - -the bellhousing and flywheel setup is totally different. You can fabricate a fake foot start that will resemble the original pedal inside the cab with a little ingeneuity- - -just make a spring-loaded pedal that brackets to the floor in the original position, and put a push button switch under it to activate the solenoid. If you use the original pedal and rubber boot, the difference won't be noticeable to anyone without opening the hood and looking for the mechanical linkage to the starter. Jerry Thanks for the info on the starter not bolting up and everyone else too for the advice thats is one of the coolest thing i have always loved even as a kid about these trucks is the foot activated starter si uts a must i keep that LOL | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | I just noticed you're using an automatic transmission. Be sure and incorporate a Park/Neutral safety switch in any starting system you design. It gets a little exciting when you fire it up in gear! Jerry
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I just noticed you're using an automatic transmission. Be sure and incorporate a Park/Neutral safety switch in any starting system you design. It gets a little exciting when you fire it up in gear! Jerry It's like pulling the arm on a slot machine u either get to pull it again or HIT the jackpot LOL | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Thought I'd add to this old thread rather than create a new one. Here's what I came up with to have a foot starter with my 250/200-4R in my 57 3100. I used a foot starter switch for a tractor ( Tractor Supply #0236643}. It will bolt to the floor and fit through the hole for the stock linkage. I built an adapter to allow me to attach the stock foot pedal to the switch. Here's a pic of the parts. And a pic of it assembled. After installing the rubber boot over it, it should look nearly stock. Comments welcomed. regards, Leon | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Looking good! That's the starter switch that fits the Farmall Cub and several other early-1950's tractors that are still in use around my area. Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thought I'd add to this old thread rather than create a new one. Here's what I came up with to have a foot starter with my 250/200-4R in my 57 3100. I used a foot starter switch for a tractor ( Tractor Supply #0236643}. It will bolt to the floor and fit through the hole for the stock linkage. I built an adapter to allow me to attach the stock foot pedal to the switch. Here's a pic of the parts. And a pic of it assembled. After installing the rubber boot over it, it should look nearly stock. Comments welcomed. regards, Leon I think this one should be made into a tech Tip!  | | |
