| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | Trying to locate a Bushing remover tool. All ready check with the Filling station, Chevys of the 40's and NCA, no luck finding one, any ideals where I can buy one? Thanks Rob | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The Filling Station lists them, are they out? Filling Station Listing
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Classic Parts of America lists one. bushing puller Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The bushing pullers linked to will not pull an Okie/ Oakie.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Rob,
If you've got the driveline pulled out, a 6' or so length of pipe jammed up the torque tube will knock it right out with a little applied force with a sledge.
If my memory is right, the earlier types had a small metal dowel holding the bushings (2 of them) in place which needs to be removed.
What year of truck are you working on?
Jeff
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Rob,
Jeff More specifically, a 6' length of 1" pipe with a pipe coupler screwed to the "business" end. Make sure the couple OD is a tad smaller than 1.625" or you will only be pounding on the "step" inside the torque tube. | | |
