0 members (),
188
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Hey All, I got a 54 3100 with the stock doors, (push button handels and vent window). Im wondering if any of you have installed a one piece window to eliminate the vent window and still kept the push button handles? Can it be done failry easily? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It's been done a lot, but you probably won't find the answer here. You're better off to check a board for customized trucks. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you are going to some fairly major mods why not get rid of the LOUSY GM latch design and go with bear claw latches. There is an outfit called "Trique Latches" that makes an all bolt in no welding required set up for the 47-51 doors.
Evan
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | THAT's what I've been looking for, coilover. I can NOT get these old doors to adjust right, no matter WHAT I do, and I am frustrated by them. I will be looking into the Trique Latches. Thank you very much for the tip!!!
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | http://www.speedwaymotors.com/Trique-1947-51-Chevy-Pickup-Bolt-In-Bear-Claw-Door-Latches,46361.html
$345.99
(Ouch...)
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I probably should too. My driver's side door opened up on me this morning while I was driving down the road and I'm SICK of it. I want these doors fixed once and for all!!!
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Interesting, well looks like I will be converting all my doors to that bear claw, so it wont work with the 51-54 doors? And would I be able to use the push button handle on the 47-51 doors with the bear claw? | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | If there is a compatibility issue with the different AD doors, then that could still be a problem for me. I have a 1952, with 1949 doors because the guy who I bought the truck from wanted the vent windows.
You know what I might end up having to do? I might have to roll up my sleeves, buy the mechanism I want, and do whatever cutting and welding I need to do to make it work. And I'll bet it will come in cheaper than $345 too, provided I do it myself.
...Frustrating.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have a 48 cab with 48 doors (original) Plan to use 52 door handles on it because I like them, need to weld in the proper reinforcing plate from the 52 and change a few holes in the door skin. Also using aftermarket latches in the swap. Not sure if later model latches fit the older doors (with exception of outside handles) I'd guess they do?
Grigg | | |
