0 members (),
166
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | I am working on rebuilding a Harrison recirculating heater (H-02-47) and am trying to find brushes for the 6 volt motor. The motor is a Delco Appliance 5047683
I have searched and read wh31ere many people said they replaced the brushes but cannot find a source in any of those threads. Tried Napa in person and looked on the Jim Carter and Classic Parts websited but could not find any.
Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you need to check with an auto electric shop, physical size is what's relevant, and the wire terminal type
Bill | | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | what exactly are you referring to when you say "auto electric shop"? Im assuming you are not talking about the typical napa/autozone store.
Should Napa be able to find me some brushes if I give them the physical size?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I mean a shop that does auto electrical repairs, if you don't have a phone book do a search .... NAPA is an auto parts store, they could get you a new motor, doubt they'll have much for DC motor repair Bill | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Carbon brushes don't have any idea whether they're in an automotive application, a skilsaw, or a vacuum cleaner. Check with an appliance repair shop, and try to match up a brush that's about the right size and length. If it's a little too big, a file will take it down to size quickly. If the coppper wire attached to it isn't exactly right, clip it off close to the old brush and solder the original lead onto the new brush lead. Sometimes it's necessary to get creative with this antique stuff! Jerry
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Thanks for the suggestions Bill and Jerry. Ill have another go at this tomorrow. | | |
