0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I added a couple of new pictures pages 3 and 4. The bodyman is finally spraying the inside of the cab! I should get the cab back in the next couple of weeks. I've got the wheels blasted and primed and at the bodyman's. I'm really getting excited. I even cleaned up the old radio and fixed a broken wire and got it working again.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Tom, The truck looks great! What color is the inside of the cab? Looks silver, but can you be specific? Also, the engine looks great. I also have a 230ci, so I want to know the paint code for the engine too. Jay | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Jay,
My painter took the transmission cover in to a paint supply shop and they did a digital analysis of the color. I think the factory used something called "Fawn". I'm not sure it is exactly correct but I sure do like how it came out though. I should get the cab back in a week or so. I'm having it done in two tone. The red is '65 corvette rally red. I know that wasn't available for the trucks but I really liked the color. The white is an off-white chevy 526.
For the engine I used Eastwood ceramic Chevy 6 Cyl Blue Engine paint 51617ZP. I haven't fired up the engine yet, been waiting for the cab then wire and run the exhaust pipe. The color looks great. I'm curious to see if it changes when it gets heated up.
I looked at your sight with all of the great pictures. Looks like we've been through the same process. Good luck!
| | | | | Joined: Sep 2012 Posts: 19 New Guy | | New Guy Joined: Sep 2012 Posts: 19 | Very nice truck. Everything looks great.
Where did you find the instrument cluster? I need to refurbish or replace mine. I have the warning lights version and would like to improve on that but don't want to go all the way to a digital cluster. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I need to refurbish or replace mine. I have the warning lights version and would like to improve on that but don't want to go all the way to a digital cluster. I sent you a PM with some info on gauge clusters. Are you interested in modifying your current cluster by adding gauges or doing a complete upgrade by swapping out all the gauges? | | | | | Joined: Sep 2011 Posts: 1,462 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,462 | What Pontiac is that vacuum gauge out of?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | The instrument cluster came with the truck. I took it apart and cleaned it up well, painted the needles, and polished the lens, and painted the ring around the cluster.
I'm not sure what pontiac the gauge came out of. I think it is a console gauge on something like a GTO. There are a bunch on ebay. I had to take it out of the housing and it fit really well in the left side. I had to dremel a little bit of the cluster but it was much or difficult.
I still want to put a tach in the other opening. I can't find one other than the ones for a V8. I might have to make some sort of circuit to make one of those work.
| | | | | Joined: Sep 2012 Posts: 19 New Guy | | New Guy Joined: Sep 2012 Posts: 19 | My preference would be to refurbish mine or get an original one with gauges instead of warning lights and then refurbish it. | | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | Enjoyed your photo album very much.
Nice work. | | |
