7 members (Lightholder's Dad, 1955 1 Series, 55shaker, DuckRancher, Jon G, 2 invisible), 67 guests, and 3 robots.
Topics128,202
Posts1,057,409
Members48,471
I have a stock 1949 1/2 ton truck and thinking about putting a chevy 350 in it and wondering if it would be too heavy for the original frame or if i had to make any changes to the frame and what the best suggestions were
just do it, a 350 will be lighter than the original 6 cyl - see here
You shouldn't have 2 separate topics about this. I replied to your other topic. You may consider boxing the frame.
My 46 GMC on Photobucket
Rather than use the two individual motor mounts (one per frame side) I would suggest using the cross member motor mount. I have not seen it but rumour has it that by not using the cross member mounts the V8 would act like a wedge and separate the frame.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
While the SBC is lighter than the stovebolt 6, the mounting style for the SBC puts different stresses on the frame. The engine side mounts will tend to twist the top of the frame inwards and the bottom outwards. A crossmember style mount will tend to counter this. I don't know of any published analysis on the AD frame that would say whether or not it can handle the stresses, but Chassis Engineering Inc, recommends a crossmember style frame mount for any frame wider than 25 inches (link).
regards,
Leon
