5 members (Hotrod Lincoln, Otto Skorzeny, Jack Ryan, Slick Willy, 1 invisible), 123 guests, and 1 robot.
Topics128,162
Posts1,056,925
Members48,458
"MONGO"
"MONGO"
Ok, for some time I've wanted a radio to fill that void in my dash but the price on radio's for 47-53 trucks is so high, and now that the only AM station I liked in our area is gone. I looked at some of the aftermarket one's that fit the holes but I really would like it to look original. Some time back I bought the plastic pieces from CD (knobs, Dialhousing, etc.)and have been meaning to build a wooden box to house a modern radio the same size as the original radio. I have a couple Sony headunits laying around that have a remote plug on them so I plan on interfacing the modern radio via the stock radio knobs and buttons. Sunday I spent a couple hours with a cabinet maker buddie of mine and built the box, thought I'd share and see what you guys think.
Pics Here
The box is actually 1.5 inches deeper than the stock radio I did this to make more room for the wires on the back of the modern headunit. After test fitting the only negative for that is that I have to open the cowl vent to install the radio but after that it opens and closes as normal.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
Yo Bro, I think I like your idea and am anxious to see how it turns out. Specifically I'd like to know what you do for knobs on a modern radio with the split stems. They are smaller than the original stems so those new knobs you got from C-D won't fit. That's the problem I have with the new Custom Autosound unit in the 53'. Gawdawwwfulll knobs they sent with it. I'll be watching.
p.s. - how are you coming with that extended cab I saw in your garage?
Dave
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
"MONGO"
"MONGO"
Dave,
I'll prob. be making my own shafts for my setup so we'll see how that turns out when I get that far.
The extended cab is on hold for a time, I've put it into storage up at the farm. Too many projects going on at once.
MONGO
Mongo's Garage
That Mongo is something else!
Tom E.
1953 GMC, 1953 BUICK ROADMASTER
(I was born in 1953)
