8 members (3800GUY, farmallb, Wayne67vert, Otto Skorzeny, Tiny, dt235sd, Steelonsteel, 1 invisible),
45
0
Mod | | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | As I'm scraping off the old undercoating from my '59 front fenders to do metal work, I began thinking of how well this preserved the metal. If the original owner paid extra for this, I think I'm the benefactor. I want to apply something when I'm ready for the finishing part of this project. One thing that came to mind is truck liner... else I was thinking primer. I decided to pop in here to see what you guys thought. What did you use? Jerry | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My personal experience with undercoating is that it usually causes more problems than it fixes. Nearly every installer blocked drain holes with the undercoat, causing water retention and more rust than there would have been had it all been left alone. A far better solution IMHO is to regularly wash the under side of the body during salt season and to make sure the drain holes are open.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Nothing is better than a good epoxy primer on clean metal.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Thanks for the tip, Tiny. I'm disassembling everything on the truck to rework/restore. I just finished the doors and they have drain provisions. When I get down to the frame, I'll do POR15... maybe I should get the POR15 earlier and use IT on the underside of my fenders. CASO how does that sound? Or is Epoxy Primer less expense for the same result? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used bed liner for under cab and fenders. I have no issues with rust or salt where I live, but wanted some protection from heat and noise. very happy with the results ...pic 1... ...pic2... ...pic3... good luck | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 |  Thanks! Jerry | | | | | Joined: Jan 2012 Posts: 29 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 29 | Upol Raptor is what I used. You can purchase a kit off Ebay.
1948 3100 1948 Fleetline Areo 1951 Suburban Carryall ( http://photobucket.com/51Burb ) 1957 3100 " Tell me who U Hang with & I'll Tell U who You are "!
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jerry,i'm an advocate of POR-15,i've never been a fan of textured underseal,I imagine the rough surface would be more likely to give dirt and crud a key to stick. I used POR extensively,here's a picture of the underside of my rear fenders.I double coated them so I hope they'll be good for another 60+ years! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I used Herculiner on the floor and bed of my Jeep CJ5 so I have some of that left over and available to use. Though I agree is has texture and could allow dirt to stick, I don't think the dirt (or gravel) could ever penetrate to damage the metal... It's texture would deflect gravel. Removal of the bedliner stuff might be a bear though I doubt that would ever be anytime soon... or in my lifetime anyway. The stuff originally used on the truck fenders was like tar, or WAS tar, I'm not sure. I'm using a scraper to remove it and it's a difficult job, but I can see it was very effective in it's purpose. It was obviously applied after the truck was assembled, as it was glopped on thick in some areas and thin in others. At least with the fenders off, I would be able to put a nice even coating of whatever I use. I'm leaving that open, because I plan on buying some POR15 for the frame when I get the cab and bed off... so really I guess I could go either way. I'm assuming a gallon of POR15 will do the frame and enough left over for all the fender undersides? I appreciate all the comments. It's always interesting to see what fellow bolters are doing and how well it worked... and I didn't find any posts on this topic. Jerry | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Thanks for the tip, Tiny. I'm disassembling everything on the truck to rework/restore. I just finished the doors and they have drain provisions. When I get down to the frame, I'll do POR15... maybe I should get the POR15 earlier and use IT on the underside of my fenders. CASO how does that sound? Or is Epoxy Primer less expense for the same result? Por 15 @ Eastwood 1gal is 150 bucks SPI epoxy primer. 2 gals for 180 bucks Every bit as good as PPG's and better than Por imo. Took a year of research before I came to that opinion but for the ease of use and simplicity of only buying one product to use for primer, build coats, and sealer (water proof all th way) I found it hard to beat.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | CASO, is a hardener required for the primer? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | The primer comes in 2- 1 gal cans... Part A and Part B mix 1:1 or reduce to use as sealer. Comes in qt's as well but for a full project 2 gals works pretty good. I I'd say I used two gals up on the cab (inside and out) by the time I was done blocking. I'm just now ordering another 2 gal kit to finish up the bed but plan on using the left overs to reseal the metal garage doors that have started to rust m(once I get the blasted) one thing I really like about the EP is I can get things stripped and in EP then let it sit till I'm ready for it...
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jerry for what it's worth a quart of POR-15 did virtually my whole chassis. It covers particularly well even when brushed,due in part to the 80% solids.
My main concern about buying a gallon of the stuff would be the use and storage of it. Once opened you really have to make sure you don't let the lid get too gunked up with paint as it's darn near impossible to get the lid back off! Some folks puncture the lid,decant what they need to use and then seal it with duct tape. Others use a sheet of polythene or similar between the lid and tin.
I opted to buy smaller tins,which was a slightly more expensive way to do it,but it suited my time frame and wallet!
Finally....If do do decide to go the POR route most importantly,don't forget to wear a mask,long sleeves and rubber gloves. Oh and I did say wear a mask!!! (Been there, done that and suffered the effects etc...) 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | A quart... I never would've imagined that. Leaf springs, axle, front suspension and all? I appreciate the tip on dispensing and sealing too, as well as the caution for saftey... well noted, my friend. I will definitely be using the POR15 on my frame and applying it with a brush. I'm leaning toward my herculiner for the fender undersides, only because I have it on hand and it should work well. I also planned on using the herculiner on my inside step and floor of the truck, the raised ribs of my steps on the fenders and on the flat step-up areas of my fabricated rear bumper. Jerry | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There's nothing wrong with undercoating, provided everything underneath it is prepped and it's not trapping any moisture or rust. This is where the issues come in. As well, you need to make sure any drains are clear as was already mentioned. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Sorry I may not have mentioned, this is for my '59 truck and the fenders are on a bench. I'm just looking at coating the inside areas of the fenders surrounding the wheels and I'll be using a brush so the application will be even and should turn out pretty nice when assembled. I'll be sure everything is dry. Thanks! Jerry | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jerry, By 'the chassis' I meant just the totally bare frame,sorry if I mislead you but even so a quart did go a long way! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Would applying POR 15 to the frame, driveshaft, and axle housings be a comparable substitute for a powder coating?
Mike | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Mike, I believe a lot of folks on here would say 'yes' to that. I plan on using POR15 on the frame and anything else I want to protect. I'm going to get a gallon so I can cover all my bases while I have the truck disassembled. Since I'm taking my time with the fenders, I could use it on the inside of them as well... still thinking...  Jerry | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Would applying POR 15 to the frame, driveshaft, and axle housings be a comparable substitute for a powder coating? Mike Mike,i'm no expert but assuming you follow the prep and application properly i've found the POR paint is really tough,I spilt a small amount on my work bench and 40 grit sandpaper would hardly even mark it! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
