3 members (hardshell, klhansen, ShopRag), 44 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#887776 10/08/2012 6:11 AM
A newbie here that got some good advice on parts purchase. Thought I would give an update and share some pics.
We disassembled to the frame in a week. Not a lot of surprises outside of how bad the floorboards were. Knew they needed attention but did not realize they were basically gone on the driver's side. The person I bought it from had put galvanized in to hide the problem.
Frame, hood and fenders are off to the sandblaster and hopefully will be back in the next 3-4 days.
I am now chasing motor mounts. The truck had some welded in mounts for the 350 that came with it. We cut those out and ground off the crappy welds. I believe the original v8 mounts that came with the 283/327 should work for the 350.
A question I have relates to the truck stance. According to the shop manual it was suppose to be 1 inch lower in front than back. I would like to see a little more rake so am thinking about doing the front brake conversion to discs and getting it with a 2 1/2 drop. Anyone have any experience with this? If so, how did it look?
Here is the link to the pics.
http://www.flickr.com/photos/88236973@N02/
Originally Posted by da_bears_da_1
I am now chasing motor mounts. The truck had some welded in mounts for the 350 that came with it. We cut those out and ground off the crappy welds. I believe the original v8 mounts that came with the 283/327 should work.
Congrats on getting all that work done. I've read a bunch on this forum.
If memory serves me well, the motor mounts for the 283 and 292 will NOT be correct for the 350. However, the mounts for the 230 & 250ci are correct for the 350, and it should bolt right in. I'm not sure about the 327 mounts. So I think you can just get mounts for a 230 and you'll be good to go.
Here's a link to an older thread that might help.
https://www.stovebolt.com/ubbthread...p;Words=mount&Search=true#Post736478
Thanks for the feedback! Will look for the 230/250 mounts.
Having a hard time finding the 230 engine perches or engine frame motor mounts. All I keep finding are the motor mounts not the frame side. Any recommended sources would be great!
Drew
