4 members (Gdads51, Otto Skorzeny, 2 invisible),
113
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 19 New Guy | | New Guy Joined: Sep 2012 Posts: 19 | A newbie here that got some good advice on parts purchase. Thought I would give an update and share some pics.
We disassembled to the frame in a week. Not a lot of surprises outside of how bad the floorboards were. Knew they needed attention but did not realize they were basically gone on the driver's side. The person I bought it from had put galvanized in to hide the problem.
Frame, hood and fenders are off to the sandblaster and hopefully will be back in the next 3-4 days.
I am now chasing motor mounts. The truck had some welded in mounts for the 350 that came with it. We cut those out and ground off the crappy welds. I believe the original v8 mounts that came with the 283/327 should work for the 350.
A question I have relates to the truck stance. According to the shop manual it was suppose to be 1 inch lower in front than back. I would like to see a little more rake so am thinking about doing the front brake conversion to discs and getting it with a 2 1/2 drop. Anyone have any experience with this? If so, how did it look?
Here is the link to the pics.
http://www.flickr.com/photos/88236973@N02/
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I am now chasing motor mounts. The truck had some welded in mounts for the 350 that came with it. We cut those out and ground off the crappy welds. I believe the original v8 mounts that came with the 283/327 should work. Congrats on getting all that work done. I've read a bunch on this forum. If memory serves me well, the motor mounts for the 283 and 292 will NOT be correct for the 350. However, the mounts for the 230 & 250ci are correct for the 350, and it should bolt right in. I'm not sure about the 327 mounts. So I think you can just get mounts for a 230 and you'll be good to go. Here's a link to an older thread that might help. https://www.stovebolt.com/ubbthread...p;Words=mount&Search=true#Post736478 | | | | | Joined: Sep 2012 Posts: 19 New Guy | | New Guy Joined: Sep 2012 Posts: 19 | Thanks for the feedback! Will look for the 230/250 mounts. | | | | | Joined: Sep 2012 Posts: 19 New Guy | | New Guy Joined: Sep 2012 Posts: 19 | Having a hard time finding the 230 engine perches or engine frame motor mounts. All I keep finding are the motor mounts not the frame side. Any recommended sources would be great! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
