1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Hello- I have a 46' with a 235 engine and I had a new rope seal installed last year and I still haven't solved the leaking problem. Can a person realistically ever stop the leak with a rope seal, or is it something you just have to live with. Thanks. Jim- | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | Yes, millions of engines were sealed with rope. If you used a seal from a modern kit, then its probably a bad seal. The manufacturers took out the asbestos years back and the seals just fall apart with out it. Best Gasket Company now sells a very good replacement. It holds together like the old stuff and works great.
Joe | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Thanks Joe, I appreciate your help. | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | I see that Best Gasket Company sells a rubber rear seal as well. Has anyone installed one of these and will they properly fit a 1954 Chevrolet 235 engine. Thanks. Jim-
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Check out this site on installing the rear seal. http://www.chevytrucks.org/tech/bobadler-1.htmI used his method and NO LEAK!  Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Thanks Harold,allthis information is very helpful. I ordered a new rope seal today. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | |
