6 members (mo2cyl, Stovebolt48, tclederman, asilverblazer, Bill Hanlon, Wayne67vert), 193 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#888114 10/09/2012 10:01 AM
Hello-
I have a 46' with a 235 engine and I had a new rope seal installed last year and I still haven't solved the leaking problem.
Can a person realistically ever stop the leak with a rope seal, or is it something you just have to live with. Thanks.
Jim-
Yes, millions of engines were sealed with rope. If you used a seal from a modern kit, then its probably a bad seal. The manufacturers took out the asbestos years back and the seals just fall apart with out it. Best Gasket Company now sells a very good replacement. It holds together like the old stuff and works great.
Joe
Thanks Joe, I appreciate your help.
I see that Best Gasket Company sells a rubber rear seal as well. Has anyone installed one of these and will they properly fit a 1954 Chevrolet 235 engine. Thanks.
Jim-
Check out this site on installing the rear seal.
http://www.chevytrucks.org/tech/bobadler-1.htm
I used his method and NO LEAK! yahoo
Harold
Harold
Thanks Harold,allthis information is very helpful. I ordered a new rope seal today.
1952 Chevrolet 3800 pickup
---All pictures---
