0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi all, I have a very small leak in my heater.drip every 3-5 seconds or so. Is there a home remedy to fix this without taking it into a shop Thanks Rick
Rick 58 3600 4 on the floor
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the "home" remedy is to take the heater apart and find out what the problem is, and as it's likely to be the core, or [if a deluxe version] the Ranco valve, buy some new parts
Bill | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Yup I did pull it out an took it apart as far as you can. Yes it seems to be in the core. I'm not sure what a ranco valve is. I dont seem to be able to pinpoint the location of leak as it comes to the lowest point
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | plug one tube of the core, put a piece of hose on the other tube, dunk the core in a bucket of water and blow in the tube as hard as you can, watching for bubbles, could be leaking at a seam that you could re-solder - if it's leaking in the body of the core you'll need to get a rad shop to re-core it or find a new one
Bill | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Thank you sir I shall try that
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I was teasing the local high school auto-tech teacher about fixing cars in crazy ways. I asked him about putting eggs in radiators to stop leaks (don't remember where I heard that one. . .) He said, "No, but pepper works for small leaks. The pepper 'finds' the small hole and will fill it up!" Might be worth a try for a leak that small. Let us know what you find.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I believe it was only egg whites that should be uses. And, yes, back in the 60's I do remember adding pepper to plug a small leak. I also remember pinching off the tubes of a leak as a temporary fix.
For the heater, I'll bet the core is too far gone to salvage.
Should not be too bad to replace. I'd bet you can do it yourself!
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Never seen any cores available for TF trucks? You can make a core with a tight serpentine copper layout maybe, 1/4 or 3/8 tubing? It's just some hot water to blow over. Make it fit in the same space as the core, use larger copper tube on each end to accept the heater hose. never done this, just brainstorming. maybe an inlet valve to control flow rate so you can tweek it. Sounds like a crazy idea to me. Easy to make anyway if they don't make cores anymore. Only two leak points and they would be outside the cab. Eggs and pepper, I'm getting hungry for breakfast.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There are dozens of cores for a variety of applications for sale on eBay every day may get lucky or find something close from another application? Worth a look if all you want is heat not originality. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | " Bars Leaks " saved my butt a couple of times for small rad /heater leaks. I wouldn't want to use it on a modern setup, but might work on the old stuff. | | |
