| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I want to put on another couple coats of clear, but i finished the base/clearcoats a couple weeks ago. Am i correct in assuming i have to wetsand prior to any new coats? If so, what sandpaper grit? Thanks, Joe | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | The product sheet for the clearcoat I used (PPG) called for 2 to 3 coats. I asked the dealer and they recommended no more than a light 3rd coat. Told me todays clearcoats are not like the older produts, best to stay with the instructions. My two cents anyway.
Mike | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Yes you can, even though its not recommended you will be ok. basicly what you will be doing is a respray. Wet sand with 1000 or 1200 & go with 2 coats. You may notice that it lays down better than it did the first time.
Most manufacturers will recommend more than 2 coats only if you plan on doing a lot of sanding & buffing. Reason is sanding & buffing removes mils, which is paint thickness. if you remove too much mils the clear wont hold up to the sun & delaminate. Thats whan you see the clear blow off in sheets a year or 2 later.
| | | | | Joined: Jan 2012 Posts: 29 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 29 | Watsjoe. I always spray 2 heavy coats of clear and then wet sand with 1200, re wipe, tac rag and relay a couple more coats of clear. Then start the color sanding process and buff. You'll get a mirror finish with great dept.
1948 3100 1948 Fleetline Areo 1951 Suburban Carryall ( http://photobucket.com/51Burb ) 1957 3100 " Tell me who U Hang with & I'll Tell U who You are "!
