5 members (Donf, Bill Hanlon, rfs56trk, baldeagle, Oswald), 42 guests, and 1 robot.
Topics128,014
Posts1,055,332
Members48,419
#886430 10/02/2012 2:39 PM
I want to put on another couple coats of clear, but i finished the base/clearcoats a couple weeks ago. Am i correct in assuming i have to wetsand prior to any new coats? If so, what sandpaper grit? Thanks, Joe
watsjoe #886519 10/02/2012 7:59 PM
The product sheet for the clearcoat I used (PPG) called for 2 to 3 coats. I asked the dealer and they recommended no more than a light 3rd coat. Told me todays clearcoats are not like the older produts, best to stay with the instructions. My two cents anyway.
Mike
martinmikey #886526 10/02/2012 8:25 PM
Yes you can, even though its not recommended you will be ok. basicly what you will be doing is a respray.
Wet sand with 1000 or 1200 & go with 2 coats.
You may notice that it lays down better than it did the first time.
Most manufacturers will recommend more than 2 coats only if you plan on doing a lot of sanding & buffing. Reason is sanding & buffing removes mils, which is paint thickness.
if you remove too much mils the clear wont hold up to the sun & delaminate. Thats whan you see the clear blow off in sheets a year or 2 later.
watsjoe #888374 10/10/2012 12:50 AM
Watsjoe. I always spray 2 heavy coats of clear and then wet sand with 1200, re wipe, tac rag and relay a couple more coats of clear. Then start the color sanding process and buff. You'll get a mirror finish with great dept.
1948 3100
1948 Fleetline Areo
1951 Suburban Carryall ( http://photobucket.com/51Burb )
1957 3100
" Tell me who U Hang with & I'll Tell U who You are "!
