3 members (Hotrod Lincoln, Guitplayer, Robert Crandall), 86 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
Hi, my truck's headlights work fine in low beam but when the dimmer switch is depressed to engauge the highs it turns the headlights off. any thoughts? I figure on pulling the dimmer out and inspecting it first then check it for continuity in it's different positions but i figured I'd ask ppl that know more than me about these trucks first.
H Online: Content
Two possibilities- - - -both high beams burned out, or a bad dimmer switch. Try applying voltage directly to the headlight connections with a jumper wire at the back of the headlights. Two wires will be high and low beam, the other one is the ground. DON'T attach the hot wire to the ground, you'll get a big arc! I'm betting on a bad dimmer switch, they had a habit of failing pretty often.
My money is on the dimmer switch. Seen alot of them melt down, usually out in the middle of nowhere.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
