1 members (Wickedbass),
33
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | Those delco 6 volt starters.. What's the differance from Chevy or GMC,,, Is it CW or CCW,,, or does just hooking it up postive ground or neg ground make it turn differnt directions.
I like fixing stuff.
| | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | I don't know the difference between chevy, GMC etc. but I do know positive or negative ground has no effect on which way the starter turns. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Like stated above, the pos. neg. ground makes no difference on the starter rotation. Looks like the Chevy and GMC truck starters from the 40s up until the 1st production 55s were pretty much the same. I know from experience that the shift lever that throws the drive in was different on the GMC and because of this it made the drive end housing different.....they were interchangeable but different....have yet to figure that one out. After 55 GMC went to more "odd ball" starters with different housings, starter drives etc. Using Buick motors in the GMCs made them that much more different...along with motors such as a 270, 302, 316 etc..Most all of them called for different housings, drives etc. Ken | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd like to see the source for Kennethw's information. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | I have the factory Delco Remy starter and generator catalogs from 1930s and up. Ken
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have the factory Delco Remy starter and generator catalogs from 1930s and up. Ken You mentioned Buick motors. These manuals tell you GMC used Buick engines after 1955? Or did you mean Buick starter motors? GMC V8s of the late '50s were based on Pontiac engines. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Didn't one of the Chevy big rigs use a nailhead Buick V-8? Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the TF series used a 322 they called the 'Loadmaster'
Bill | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Thank you Cletis, exactly what I meant to say. Some of the starter motors used in some of the GMC trucks shared the same starters as some of the Buicks and other GM cars. They would all have had different Delco numbers of course but aftermarket numbers grouped them together, this way you could easily figure out that one specific starter may have fit other motors regardless of the specific Delco number. Kind of a cheat sheet for the original Delco numbers. Yes on the Buick engine for 56 CHEVY. 1956 Truck, Series 9000 and 10000 had optional 322 Buick engine. There was even an optional power steering generator specific for this truck and motor that was different from the basic power steering generator used on the standard cars and smaller trucks. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks for the clarification. | | |
