0 members (), 51 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#886204 10/01/2012 7:19 PM
Those delco 6 volt starters.. What's the differance from Chevy or GMC,,, Is it CW or CCW,,, or does just hooking it up postive ground or neg ground make it turn differnt directions.
I like fixing stuff.
katrina #886226 10/01/2012 8:33 PM
I don't know the difference between chevy, GMC etc. but I do know positive or negative ground has no effect on which way the starter turns.
katrina #886263 10/01/2012 9:53 PM
Like stated above, the pos. neg. ground makes no difference on the starter rotation. Looks like the Chevy and GMC truck starters from the 40s up until the 1st production 55s were pretty much the same. I know from experience that the shift lever that throws the drive in was different on the GMC and because of this it made the drive end housing different.....they were interchangeable but different....have yet to figure that one out. After 55 GMC went to more "odd ball" starters with different housings, starter drives etc. Using Buick motors in the GMCs made them that much more different...along with motors such as a 270, 302, 316 etc..Most all of them called for different housings, drives etc.
Ken
Kennethw #886292 10/01/2012 11:27 PM
I'd like to see the source for Kennethw's information.
Cletis #886296 10/01/2012 11:54 PM
I have the factory Delco Remy starter and generator catalogs from 1930s and up.
Ken
Kennethw #886434 10/02/2012 3:03 PM
Ken
You mentioned Buick motors. These manuals tell you GMC used Buick engines after 1955? Or did you mean Buick starter motors?
GMC V8s of the late '50s were based on Pontiac engines.
katrina #886497 10/02/2012 6:42 PM
H Online: Content
Didn't one of the Chevy big rigs use a nailhead Buick V-8?
katrina #886503 10/02/2012 7:09 PM
the TF series used a 322 they called the 'Loadmaster'
katrina #886539 10/02/2012 9:32 PM
Thank you Cletis, exactly what I meant to say. Some of the starter motors used in some of the GMC trucks shared the same starters as some of the Buicks and other GM cars. They would all have had different Delco numbers of course but aftermarket numbers grouped them together, this way you could easily figure out that one specific starter may have fit other motors regardless of the specific Delco number. Kind of a cheat sheet for the original Delco numbers.
Yes on the Buick engine for 56 CHEVY. 1956 Truck, Series 9000 and 10000 had optional 322 Buick engine. There was even an optional power steering generator specific for this truck and motor that was different from the basic power steering generator used on the standard cars and smaller trucks.
katrina #886548 10/02/2012 10:10 PM
Thanks for the clarification.
