7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | It's it possible to get the radio to work without an antenna? Want 2 hook it up don't want to drill hole in body. Any ideas or tips. Thx, Where do I post 4 the bracket 4 under dash bracket 4 the speaker, meaning I need the bracket? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You can make a test antenna with a four foot piece of hookup wire. Bare about 1/4" and plug that into the middle hole in the antenna socket.
What model of radio and truck are you working with? | | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | Trucks in the shop so it could be a couple of weeks before I can answer that. It's a 1960 suburban with a 61 radio, was that Delco stock? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | GM would have had a radio for that truck for sure. Someone familiar with it can answer the bracket question. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | put a post in the parts wanted for the brackets, there's a number of members with lots of 60-66 parts, someone will have them
Bill | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have an under the dash antenna that mounts with double back tape. available at a FLAPS. they don't work as well as one on the outside but gets local station very well. This what i have. It says window but mine is glued too the ac unit under the dash.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
