0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#885448 09/29/2012 12:02 AM
It's it possible to get the radio to work without an antenna? Want 2 hook it up don't want to drill hole in body. Any ideas or tips. Thx, Where do I post 4 the bracket 4 under dash bracket 4 the speaker, meaning I need the bracket?
You can make a test antenna with a four foot piece of hookup wire. Bare about 1/4" and plug that into the middle hole in the antenna socket.
What model of radio and truck are you working with?
1951 1 Ton Completed
Trucks in the shop so it could be a couple of weeks before I can answer that. It's a 1960 suburban with a 61 radio, was that Delco stock?
GM would have had a radio for that truck for sure. Someone familiar with it can answer the bracket question.
put a post in the parts wanted for the brackets, there's a number of members with lots of 60-66 parts, someone will have them
I have an under the dash antenna that mounts with double back tape. available at a FLAPS. they don't work as well as one on the outside but gets local station very well. This what i have. It says window but mine is glued too the ac unit under the dash.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Moderated by  truckernix
