1 members (NJC),
151
0
Mod | | | Forums66 Topics128,117 Posts1,056,296 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What outer-diameter size of vacuum lines were used on the d-a fuel pump (47-55)?
I have two sets from used pumps that were installed by owners. They are had 1/4" outer diameter lines. Brass adapters are in the threaded pump-ports (the tube ends are compression/ferrule fittings).
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Peter,
Yes, I have seen those. Thanks. I miss Denny. I hope he is getting settled in his new house, yard, and shop.
It looks like they are smaller than the 5/16 fuel line. My guess is that they are not 3/16, but that is my quandary: 3/16 or 1/4. I might send Denny a PM or email.
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Tim,
I agree with your analysis both of the vacuum line and Denny. The two of you are some of the best go to guys we have. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Mine has 1/4" tubing on my 37 Buick with a DA pump and the same on a customers 40 Pontiac. One is a straight 8 and the other a flathead 6 so it seems GM used the 1/4 for all. This may or may not be of help.
Evan
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Tim, my impression is that they were dealer installed, not factory installed. Is that correct?
Fred | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Fred - Don't mean to jump in front of Tim's answer to your question -- The Fuel & Vacuum Pump was factory installed. 1954 RPO #340, $8.50 list price. Factory Assembly Manual instructions Section 0, Sheet 18.00 Of course it could be installed by the dealer, too. '29-'54 MPC: "52-54 ALL (2nd design) .... fuel and vacuum, dbl. action (AC-9797 .... 5592675 .... $14.65" The second design had in-out ports for fuel line that were angled 20deg to the block in order to clear the side mounted motor mounts that were used on passenger cars starting in 1952. I searched through the MPC and FAM, but couldn't find reference to the size of the lines.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jump in front any time, Lonnie.
Thanks, everyone, for the posts.
I'll go with 1/4", since I already have those fittings. I'll be using copper-nickel tubing from Advance-Auto (best price).
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Bigger is always better on vacuum lines- - - -that's why the big trucks with the Hydrovac used 1/2" hoses from the manifold to the reservoir tank. If you've got an option when installing a new system, use 5/16" hoses and hard lines, and hide a small reserve tank with a one-way check valve somewhere out of sight. It might not be OEM, but it will make the wipers and other vacuum-operated accessories work much better. The softball-sized round plastic vacuum reservoirs from a newer car will mount somewhere out of sight down in a fender well, etc. and won't detract from the antique appearance. Jerry
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I have the dual action pump from Chev's of the 40s. It takes 1/4" MNPT. Per Jerry's suggestion, I'm mounting a vacuum reservoir tank under the cab and using a brass 1/4" MNPT fitting to a flared 1/4" ID copper line. I'm using an Erson tank which is a bit bigger than a softball but I recently found these 1980-82 Corvette headlamp tanks. They look like tin cans so they blend in with the antique look a bit better. Mine looks like this... Erson vacuum reserviour tank Mine will get tucked up in a frame rail or hidden somewhere. ...the difference is, I got it for $20 with a gauge and all the fittings where as the Vette tank is +/-$60 depending on where you find it. That said, I might get the vette tank just for the look and sell mine. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | BLUEMEANIE,
Where did you purchase your reservoir? Summit has it or $45
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ebay. Summit sells the exact same one. Erson, Summit, Jegs, Crane, etc. same tank. In fact, if you search "vacuum tank reservoir" the first auction to come up is under $3 with four days left for the same tank plus a new Autometer gauge. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Those tin can tanks were original equipment on a lot of 60's and 70's GM vehicles, so a salvage yard search might turn one up on vehicles of those vintages. I think a wrecking yard would just about give one away. Jerry
