Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (klhansen, NJC, UnclePaddy, Guitplayer, 1955 1 Series), 88 guests, and 3 robots.
Topics128,281
Posts1,058,460
Members48,490
Socket Breaker
Socket Breaker
hiyas folks.
I have a '65 c10 - and recently I found out(a few days ago) that the 60-66 trucks did not have the button for the hazard lights on the column - but the 67-72's did/do.
So, it appears I have a later column in my truck... go figure - everythign is is a different year so it fits with the motif. smile
Anyhoo's - I am trying to figure out which of the wires coming from the steering column is the wire for the hazard switch ?
The switch doesn't do anything at the moment, I thought I'd try to figure out how to make it flash...
Anyone have a good idea on what flasher to get to go inline on the wire?
Thanks for anything ya'll can come up with...
pics of my steerin' column...
http://woogeroo.home.mindspring.com/Matraca/img09142003/35.html
http://woogeroo.home.mindspring.com/Matraca/img09142003/36.html
-W
See if you have a brown wire unused at the bottom of the column, if so hook it to 12 volts thru another flasher. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Typical Chevy steering column wiring:
"K" = Hazard
I hope that gets ya there, bro'!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Socket Breaker
Socket Breaker
thanks fellas...
the wires I can see at the bottom of the column, then it is wrapped and wrapped in electrical tape all the way to the fuse box - so I was looking for a place to start.
thx.
-W
Socket Breaker
Socket Breaker
I see the brown wire - it comes out at the end of the coulmn and in the many wraps of electrical tape it is cut off. smile
I had this advice from dval on 60-66 truck forum at chevytalk:
Find the hazard wire on the column harness. Find a 12 volt ( ignition off ) source on the fuse panel. Connect the hazard wire to the 12 volt source WITH a Flasher Relay in the Middle of the Connection. Instant hazard lights.
now, my question is... I wander into Advance Auto parts and tell them: I want a flasher unit 12v....
then they say, what year... what make, what... etc..
So... anyone have any tips on that part of the equation?
-W
Just a two prong flasher, a 552 should work fine. They are near the bulbs, connectors etc. Brian
Socket Breaker
Socket Breaker
Thanks Brian.
You always have the good info.. smile
-W
Socket Breaker
Socket Breaker
I got the flahser wired up and now I have hazard lights! woo hoo!
I used the 552 flasher as 64Fleetside suggested.
I also put a inline 20 amp fuse in place, just in case. I'm guessin' that is enough... not sure if it is too much tho'.
How I wired it:
I have a wire to the 12v ignition off source, to a 20 amp inline fuse, to 1 prong of the two prong the flasher unit, then a wire on the other prong to the brown wire, which leads to the switch. Then I zip tied the flasher unit up out of the way. smile
The it took about 5 mins after I had found the correct wire on another day... I put an extension wire to it, took a wire that I have with alligator clips on each end, clipped one end to a 12v source and the other end to one of the prongs, then slipped on the new wire on the other prong - pulled the switch and it worked.
The most time took for this project was finding the right 12v ignition off source, then wiring everything up right.
The reason I put a fuse inline, was I was burnin' out a fuse on another source I was trying to use... so, just to be safe I added one in the new place. smile
The thread on chevytalk - where I found out about the hazards and things:
http://www.chevytalk.org/threads/sh...ge=0&vc=1&PHPSESSID=#Post1189699
this tip was in the thread as well, didn't see it until after I had wired it up, but it's a good idea:
GO IN TO YOUR LOCAL PARTS STORE AND PICK UP A HEAD LIGHT PLUG AND A FLASHER . THE FLASHER WILL PLUG RIGHT INTO IT
Anyway, if anyone is searching in the future and they find this thread, they can check it out.
Thanks to everyone!
-W
edited for type-o's and to add additional content and clarification.
Socket Breaker
Socket Breaker
Hiya peoples...
My flashers still work great, but when they are on and I hit the brake pedal, they stop flashing. The light are still on but no more flash-flash, when I let off the brake pedal they go back to flashing.
Is this normal or do I need to check something?
-W
Woogeroo,
This is a guess. If the hazard flashers are blinking brake lamps, then the flasher must be bypassed and allowed to indicate a 'steady' STOP when the pedal is depressed.
Stuart
Socket Breaker
Socket Breaker
on my '65 the flashers blink the rear lights and the front blinkers.
-W
Socket Breaker
Socket Breaker
I've been told by soem other old chevy truck guys that this action is normal.
-W
Woogeroo,
Coincedence--my 65 c10 is the same as yours --it has a hazard switch on the column that does not work. I tried to figure it out but not being wire enlightened gave up. I have to change my steering wheel, get my signals to cancel and hazard lights to work. Your questions and answers have given me a direction to go in. I wonder why the switch is on there and not wired--well at least it's there.
Try again tomorrow....
Quote
Originally posted by Woogeroo:
Hiya peoples...
-W
Woogeroo,
I believe this is normal. At least thats how mine work and it makes sense to me. Of course, I hooked up my hazard flasher myself and don't know anymore than a first grader.
Your brake lights should come on and stay on when you are depressing the brake pedal. That way drivers behind you then know you are braking.
Brian
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
