| | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i have tried this post twice.simple quistion,,are these heads interchangable?what are the advantages or disadvantages... | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Yes they are interchangeable but the 292 head might have a bigger combustion chamber, It would lower your compression, not much differant in flow numbers, they both have the same valve size. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Baldy got the long and short of it. The 194/230/250/292 heads all interchange, including the later integral. They all have the same disadvantage, Siamese intake ports. The 194 combustion chamber smaller and will up your compression, unfortunately it is all so limited performance wise because of valve shrouding. Inliners.org has a partial listing of heads and combustion chamber size. If you need to know what it takes to get performance out of one of the heads check out http://www.t6racing.org/Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | All is correct information. Stay away from the real late model heads with the intake cast into the head. Performance wise, they all will be the same, the late model with the intake cast has a two barrel carb, which might run better, but the heads are prone to heat cracks.
Your best bet is to grab the first good head you find.
For a 250, add 307 Chevrolet V8 pistons for slightly over 1 point compression increase. Its a drop in piston, just be sure its a true flat top, not the universal replacement.
Joe | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i have seen this info about the 307 pistions fitting a 250.i have also read on other forums ,where this will not work.where can i get more info about this??? | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Look on http://www.inliners.org/. They have lots of info on the 250, including the 307 piston. It's a popular modification. For a 292 you can use LP pistons for higher compression.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | For a 230 inline, use a 283 V8 piston, 250s are the same as the 307. It must be a true flat top, some of the universal replacements have lots of valve relief cuts plus a big chamfer around outside edge.
Joe | | |
