9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | I can buy a 57 gmc truck lcf. I am waiting to hear if it has the tubeless rims. Does it make sense to buy this truck and swap out the from and rear axles or should I continue to look into modernization? Will the swap be a bolt in situation? Thanks Chris
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What would you gain by using parts 6 years newer but still old, and not likely an easy swap? My first guess is it sounds like a lot of work for no appreciable gain.
Find out what the wheels are and bolt pattern, if 22.5" 5/10 lug they'll swap to the 51 with some hub bushings.
Grigg | | |
