3 members (2-Ton, carbking, Guitplayer), 291 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#884712 09/25/2012 7:56 PM
I can buy a 57 gmc truck lcf. I am waiting to hear if it has the tubeless rims.
Does it make sense to buy this truck and swap out the from and rear axles or should I continue to look into modernization? Will the swap be a bolt in situation?
Chris
What would you gain by using parts 6 years newer but still old, and not likely an easy swap?
My first guess is it sounds like a lot of work for no appreciable gain.
Find out what the wheels are and bolt pattern, if 22.5" 5/10 lug they'll swap to the 51 with some hub bushings.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
