4 members (JoergK., tclederman, Danielbolt, Peggy M), 177 guests, and 2 robots.
Topics128,175
Posts1,057,052
Members48,460
I have installed a NOS set of Guide amber fog lights on my 54 3104. They have the 6v composite bulbs. I used an 8amp reducer from the battery to the switch and when the circuit is closed you could boil water on the ceramic resistor in a few seconds. I don't believe there were 12v bulbs for these lights.
How can I reduce the voltage without heating the garage?
My rule of life: You can have anything you want; you just can't have everything you want.
Try wiring the two lights in series, ground the frist light, then run a wire from the frist light to the second on one side, then the other side of the second light to the switch.
I believe a standard 4415A bulb could fit the Guide foglights (5 1/4 inches)?
[img]http://www.whizzerick.com/fog.jpg[/img]
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
You can get the 4415A from Atlanta Light Bulb Co. on the web. I got mine there at the best price around. Quick shipping.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
http://www.atlantalightbulbs.com/
Wow! They even have bulbs for my late '40's, 6 volt Firestone Spotlight! (Made by Appleton). Bummer there is a minimum order of 10...
