| | | Forums66 Topics128,285 Posts1,058,535 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88461 06/20/2004 2:03 AM | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I have installed a NOS set of Guide amber fog lights on my 54 3104. They have the 6v composite bulbs. I used an 8amp reducer from the battery to the switch and when the circuit is closed you could boil water on the ceramic resistor in a few seconds. I don't believe there were 12v bulbs for these lights.
How can I reduce the voltage without heating the garage?
My rule of life: You can have anything you want; you just can't have everything you want.
#88462 06/20/2004 2:11 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Try wiring the two lights in series, ground the frist light, then run a wire from the frist light to the second on one side, then the other side of the second light to the switch. | | |
#88463 06/21/2004 4:12 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | I believe a standard 4415A bulb could fit the Guide foglights (5 1/4 inches)? [img] http://www.whizzerick.com/fog.jpg[/img] | | |
#88464 06/21/2004 4:16 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | You can get the 4415A from Atlanta Light Bulb Co. on the web. I got mine there at the best price around. Quick shipping. | | |
#88465 06/21/2004 6:58 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | http://www.atlantalightbulbs.com/ Wow! They even have bulbs for my late '40's, 6 volt Firestone Spotlight! (Made by Appleton). Bummer there is a minimum order of 10... | | |
