1 members (klhansen),
98
0
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88453 02/26/2003 12:33 PM | Joined: Feb 2003 Posts: 3 Junior Member | | Junior Member Joined: Feb 2003 Posts: 3 | i'm sure this is pretty elementary stuff, but i'm not much of an electrician... i'm attempting to upgrade the alternator in my '66 c10 to one with a built-in regulator. so, i would like to remove the old one. any words of wisdom before i grab the clippers? thanks in advance everybody. | | |
#88454 02/27/2003 12:45 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | are you going to a one wire alt or a three wire alt? | | |
#88455 02/27/2003 3:29 PM | Joined: Feb 2003 Posts: 3 Junior Member | | Junior Member Joined: Feb 2003 Posts: 3 | i guess what i had was a three wire since it had the one red wire and two other leads that "plugged" into it. however, the new one just takes the red lead. that red lead runs from the battery... to the regulator, where the other two leads start. from there; all 3 of those go to the horn relay and onto the alternator. the short question is: can i run the red power lead from the battery directly to the horn relay and along to the alternator; cutting out the regulator and its two leads and have the horn and everything still work?!? | | |
#88456 02/27/2003 8:47 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | With a one-wire, you want a direct lead from alternator to battery for charging. You should probably put in a separate circuit for the horn relay and jettison the old voltage reg.
Just my opinion, mind you, I've never pulled a '66 apart. :p | | |
#88457 02/28/2003 4:53 AM | Joined: Feb 2003 Posts: 3 Junior Member | | Junior Member Joined: Feb 2003 Posts: 3 | hey, thanks zenish and hedgehog. hard to see the forest through the trees sometimes. its's a new purchase after a long time hunting and waiting. maybe i need to slow down and think... | | |
#88458 03/07/2003 5:00 AM | Joined: Dec 2002 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 15 | What would be the correct way for a three wire alternator? I've got a 66 K10 that with this setup and a badly hacked up wiring harness. The red wire off the alternator broke in two last weekend so its time to 'restore' this part of the harness.
when the going gets weird, the weird turn pro
#88459 03/11/2003 7:06 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | One wire won't charge till you rev it up some, something like 1200 rpm, but charges at idle after that. You can run the big red wire (10 gauge) to the battery plus side and some cables have a small wire sticking out to connect stuff too. OR, you can just go down to the starter cable where it hooks on the starter and use a ring end to put it on there. OR, you can take off the reg you have and connect the two red wires toghether there and that will allow your gauge (volt or amp) to work and feed other things maybe inside. With that last part, just use the same wiring as what's there for old one, just take out the regulator. This worked on my 54, should work on most, I think. OR, why not just plug all the wires back into new alt, and remove the reg outside as noted above. Saves running new wires.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#88460 03/12/2003 3:09 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | on the three wire alt hook terminal 2 to the big lug on the back of the alt.take a #10 or 8 guage wire from the big lug to the plus side of the battery.hook terminal 1 to the wire from the gen light on the dash.the way i did my 64 is i unraveled the alt harness back to the old regulater which only left the gen light wire. | | |
