3 members (dunfire, Napco Man, TUTS 59), 61 guests, and 2 robots.
Topics128,035
Posts1,055,564
Have an ammeter I'd like to connect up to my '65 1002. I know the meter compares the battery voltage to the output of the regulator. What wire should I connect it to at the regulator?
Thanks in Advance!
Scott
1964 GMC 1002 Long Wideside w/305E V6 & sm420 "Blue Jeans"
1996 Harley Davidson FLHTCI
1981 Husky 250CR
http://community.webshots.com/user/gmc1002hf5669a
Red dot, center of chest ...
In general, the BAT terminal of a regulator is connected to the ammeter and the other terminal of the ammeter is connected to the battery. Ammeters have to be inline in order to read current.
Take a look at this Painless Wiring diagram, at the first two pictures:
web page
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
65, all an ammeter will tell you is if current is flowing to or from the battery. Health of the electrical system is best measured with a voltmeter, which is why you don't seem ammeters used anymore. If you are staying stock, then you will likely want to keep the ammeter.
Thanks!! That painless wiring site is really cool!
BoTi: You did get me thinking about using a voltmeter. My first truck ('68 long fleetside) had an ammeter, so I had been leaning that way, but you bring up a good point. Ohm's Law would say that either way (current or voltage) is monitoring the system, however, I think using the voltmeter is easier and potentially safer. Thanks for the input!
Scott
1981 Husky 250CR
I agree with SoTxBoTi. An ammeter doesn't actually compare voltages...although a voltage differential will cause current to flow.
It measures the total current flowing between the battery and the alternator. If current is flowing in such a manner as to charge the battery, a charging reading will be seen. If current is flowing that is draining the battery a discharge will be indicated.
The thing that I don't like about ammeters is the fact that they require all the system current to flow thru them. This can result in wires overheating due to poor connections, added complexity and just plain old high current stuff under the dash.
I prefer volt gauges...I have them in all my vehicles except my 64 C10. I've got a feeling it's gonna get a volt gauge eventually. As was mentioned, you can tell a whole lot more by reading a fairly accurate volt gauge. You can tell the condition of the battery with a small load (essentially no load if you just switch the ignition on), the battery condition under load (observed while cranking the starter), the alternator output and the load that different accessories put on the system.
It's a pretty handy tool for troubleshooting and for warning of possible problems.
But (as was pointed out) if you're going for a totally stock look, then ya gotta have the ammeter, I spose.
Just my opinion,
