| | | Forums66 Topics128,151 Posts1,057,004 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | As I now understand, after installing new king pins, you are supposed to seat a new dust cap and then "stake" it by using an 1/8" or so punch in 4 places around the perimeter.
When greasing, does the grease come out in the places where the dust cap has not been staked?
I think I botched my new dust caps by pounding them flat. Does anyone know where these can be obtained? Jim Carter and my NAPA don't have them.
Thanks!
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | funny i just did my king pins on my truck yesterday, what i did was use the old king pin and hit the plug so it wedges in the spindle hole holding it tight,there are not to be flat but just enough to tighten then in the spindle,be sure to ware eye protection when doing this too.its the same thing you would do on a freeze plug on the side of a block as long as its a flat type of freeze plug, hammering them flat is how you can take them out, i think they should be 11/16 flat plugs if you have a .922 pin. i would think some parts house should have them or at least they could order them for you. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I treat them as a freeze plug, no staking. Even take the time and effort to repair previous staking attempts. What does the shop manual say? I could be wrong but I'd be surprised if they're supposed to be staked.
Grigg | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | I got my axel back from the shop with the caps staked and they are cupped not flat and only a little grease is visible where not staked. Hope this helps Griggs | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | The shop manual says to seat the caps and then stake them at 4 points.
The grease zerks and dust caps are at different ends of the bushing so it seems that some grease must come out around the cap for it to flow fully through the channels of the bushing. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | They are both convex and can be flattened a little to make them fit tighter. I also stake mine in four places as per the manual. Your only doing the job once right? No sense in being lazy about it and if you check the grease on a reasonable basis, you shouldn't have many issues and need to swap kingpins again in your lifetime.
I doubt you'll see anything more than a tiny bit of grease if any, come out of the top. Most of it will ease out between the thrust bearings between spindle and axle if I remember correctly.
Jeff | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I just took my front axle apart the other night, mine didnt have any dust caps, but it all came apart fairly easily. It looks like the last person who did the King pins didn't put the caps back on. But they did take the time to grease everything. Everything that was greasable on that truck was well greased.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I made a cutter out of an old king pin to clean up the old staked area. If the old staking is not cleaned up it is hard to get the new end caps to seal. King Pin Cap Cutter
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Just don't pump to much grease in the zurks, if you do you can push out the plugs that are the dust covers. most likely thats what happened to Jeffl. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Thanks Benny. I like the two 1936 Coupe Pickups in your photo bucket. I have two customers with 1936 coupe pickups. I use to think they were rare but now I am starting to wonder.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | lol, They are rare,being'36 and they are still around after WW2 and not scraped out, the numbers i got was like 5800 of them made. I wonder too, I got both of them from one guy and he kept one for himself. How many are left? Who knows. Thanks Brad http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I made a cutter out of an old king pin to clean up the old staked area. If the old staking is not cleaned up it is hard to get the new end caps to seal. King Pin Cap CutterThat's a great idea. When I clean them up I use a punch with a suitably rounded end to work the metal back into place, then you don't loose any material and it's about as good as new. Still if any final cleanup is necessary your cutter would do the trick. Grigg | | |
