8 members (frogfarmer, 52Carl, KEVINSKI, Hotrod Lincoln, Rustnut, Cletus1950, 1955 1 Series, fonz8261),
98
Mod | | | Forums66 Topics128,177 Posts1,057,060 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | I've got a '58 panel with the 283 and a three speed tranny. The engine will probably be replaced and the transmission will be a 5 speed. While I'm at it, the front brakes will probably changed over to disc and I'm looking for suggestions and ideas. First, does anybody have a kit for this? If not, what would be the best (not necessarily the cheapest) way of going about this? Lastly, I'm also open to the idea of going from a 6 to a 5 lug system on all fours, so if that is the best way to do this, I'm open to suggestions. TIA.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there are kits available from a number of the vendors for front disks on the TF 1/2T's, I believe most, if not all, require going 5 bolt ... a question more appropriate to the HiPo forum, it's not panel-specific
Bill | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Other than what Bill said, 6 lug rotors are available from several vendors these days. You should swap the old style ball bearings for roller bearings when you do the job.
Best wishes,
Les | | | | | Joined: Oct 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 62 | Bought mine from CPP, and it came with the proper roller bearings Front disc Disc Brakes Bolts right on, I wanted to keep my straight axle, pulled a rear end from an early 80s Camero, had to have the spring perches welded on, all 5 lug now. Don J  | | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | I have a 3800 9 foot panel 1959 GMC with 8 lug wheels. Was thinking of a bolt on also, but really need a date correct hood. The shipper didn't tie it down and it flew off apparently.
