| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88355 02/25/2004 9:38 PM | Joined: Dec 2002 Posts: 40 Junior Member | | Junior Member Joined: Dec 2002 Posts: 40 | I just put my 50 3100 on the road, have a 350/350 drive train. I need a neutral safety switch but don't have a clue where it's located, assuming there is one. Guidence/advice is as always appreciated  | | |
#88356 02/26/2004 7:47 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I don't have a TH-350 around right now but I do have a TH-400 and a few TH-700's. I have never seen a neutral switch (or a reverse light switch) on these automatics. I think those switches are often mounted on a steering column or shifter unit (I have a B&M megashifter and it has the switches for reverse/neutral). | | |
#88357 02/26/2004 11:20 PM | Joined: Dec 2002 Posts: 40 Junior Member | | Junior Member Joined: Dec 2002 Posts: 40 | UhOh....I didn't see anything that resembled a n.s.s. on the column (69 Chevelle donor) can one be retro fitted? What's the critter look like? :confused: | | |
#88358 02/26/2004 11:42 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | In my 78 El Camino it was in the column. I do not know what it looks like - I haven't taken it out. If you need it, and it will work, let me know - I don't use it (floor shift)!
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
#88359 02/27/2004 3:25 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Check on the top side of the column tube and see if you have a square cut out section with two 5/16" screw holes on one side of the hole. The neutral safety switch bolts down with the two screws and the lower tab on the neutral safety switch fits into the notched section of the inner tube. The inner section of the tube will rotate when you move the shifter causing the contacts in the switch to make contact when your in Park and Neutral for starting and also in reverse for back-up lights.
Joe
Joe
#88360 02/27/2004 6:36 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | The neutral safety "switch" on most "later" model steering columns (those with the ignition key on the column) is actually a mechanical interlock that prevents the key from being turned into the "start" position in any gear but park and neutral.
I've converted several of these to use floor-mounted ratchet shifters and I've had to fix them in the park position and use the park/neutral switch on the floor shifter to interrupt continuity in the purple wire coming from the start switch in the column when not in park or neutral.
Other than those 2 methods, I'm not familiar with an easy way to do this on a TH350...unless you wanted to get creative and use something like a brake light switch on a bracket near the transmission shift arm. This would allow starting in Park, but not neutral. Something to consider, though. | | |
#88361 02/29/2004 6:12 AM | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | I fabricated a neutral switch on a Chevy/F*rd conversion, using a microswitch and a disc mounted to the shift quadrant on the transmission linkage at the transmission. I filed a couple of notches in the disk, and mounted the switch so its roller would fall into the low spot when park or neutral was engaged. use the "normally closed" contacts of the microswitch to engage a F*rd solenoid, and trigger the GM solenoid with that one. The GM unit draws too much current to run directly through the microswitch contacts. Jerry
