2 members (52Carl, Gdads51), 37 guests, and 3 robots.
Topics128,180
Posts1,057,161
Members48,464
I've got a baaaaad leak on my waterpump. So, I've got a new one! But, I need to squash the pulley mounting thing further down the shaft, as I've got a 235, in a '49.
What size press do I need to do this? Can I get away with a 1 Ton arbor press? Or do I need something more powerfull?
Thanks in advance!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
An arbor press should do it.
Thanks for the info, this seems like a good enough excuse to get an arbor press, and stop trying to improvise!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
If that's all you need to do a bench vice might do the trick. Be sure you support the shaft from the bottom and not press on the bearings/housing.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
come on, work with the guy, he needs justification to his wife that he needs a press.
OK, if I were looking for a shop press this is a great one.
OTC press
I used one and was quite impressed, it's a lot of press for the money and well made.
They have larger and smaller and even bench top ones as well.
Grigg
---All pictures---
