| | | Forums66 Topics128,179 Posts1,057,162 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I've got a baaaaad leak on my waterpump. So, I've got a new one! But, I need to squash the pulley mounting thing further down the shaft, as I've got a 235, in a '49.
What size press do I need to do this? Can I get away with a 1 Ton arbor press? Or do I need something more powerfull?
Thanks in advance! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | An arbor press should do it. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Thanks for the info, this seems like a good enough excuse to get an arbor press, and stop trying to improvise! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If that's all you need to do a bench vice might do the trick. Be sure you support the shaft from the bottom and not press on the bearings/housing.
Grigg | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | come on, work with the guy, he needs justification to his wife that he needs a press. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | OK, if I were looking for a shop press this is a great one. OTC press I used one and was quite im pressed, it's a lot of press for the money and well made. They have larger and smaller and even bench top ones as well. Grigg | | |
