0 members (), 85 guests, and 0 robots.
Topics128,115
Posts1,056,291
Members48,439
#883309 09/17/2012 4:51 PM
I bought a 235 yesterday (casting #3835911). After cleaning the crud off I found a Jasper rebuild sticker on it. No ID # on the sticker so Jasper couldn't tell me anything they did to it or when. The oil pan is a bluish-green and in pretty good shape. Is there any way to tell without taking it apart if it has harden valve seats or should I just add lead at fill-up just to be on the safe side?
Cyril #883310 09/17/2012 5:05 PM
no, you cant tell if there seats in there unless you take it apart. you can look at the tips of the exhaust valves and see if they are all in line with each other, that might tell you something. but maybe not, depends on the guy doing the valve job.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
also if this engine has been running lately and runs ok now, i would have to say that the engine was running on unleaded for some time.
I don't think you need to worry about it. Been running unleaded in my 235 since they came out with it. Still running strong.
Kurt
Thanks guys. I won't fire her up till next spring, still have a little frame work and get the cab over to my body guy.
Cyril #883455 09/18/2012 11:02 AM
Unless you're running it on Propane or some other kind of "dry" fuel, don't worry about hardened seats. Back when the swap to low-lead and no-lead fuel first happened, we had some problems with exhaust valve seat erosion, but for some reason it hasn't happened much lately. Maybe they changed the fuel blend in some way.
Ex Hall Monitor
Ex Hall Monitor
I've been running unleaded in "leaded" engines for years without a problem.
