| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | So I'm getting ready to start dressing my 283 to put in my '59 3100. I have two quick questions. I plan on installing an HEI distributor ( external coil ) on the 283. Will the coil I used on my Langdon HEI for the 235 I had work with the HEI I plan on installing on my 283? My second question. The 283 ( '67 ) I bought does not have a coil bracket that mounts to the intake manifold. I have found a bunch on eBay, but they range from certain years to certain models, Corvette, Belair etc...... They all look the same, is there really a difference in years of coil bracket? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | IF the HEI you are installing is a Pertronix, like the "Langdon HEI", the coil shouldn't be a problem. All the brackets should fit a standard 12v coil.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
