Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, tclederman, Youngin' Tut 59, UtahYork, Woogeroo), 37 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#882587 09/14/2012 12:14 PM
1949 GMC Pickup, motor starts fine but only when choking, can not drive when choking, motor just stops. If choke is pushed off motor kills.
New fuel pump 60 days ago, truck had been running fine daily....
jtminor #882655 09/14/2012 5:15 PM
Did you clean the gas tank?
Did this come on all of a sudden?
What brand is the carb?
Sounds like you have a vacuum leak.
My Blog
Zenith carb.....I pumped Sea Foam directly into carb....trucks running fine right now, probably junk from tank, I removed the tank and treated and sealed a few years back.
Truck has 18,000 miles, no rust, could use a new paint job, missing nothing from top to bottom...I love the truck, but it has been a bit tempermental(sp)....
Thanks for your response, what would cause a vacuum leak, where?
Have a grateful day!
Jim
jtminor #884039 09/21/2012 10:21 PM
What did you seal the tank with? Some sealers have problems with ethanol. That may be an old problem.
My GMC 270 was doing that, it turned out to be a vacuum leak and crud keeping the float needle open. The carb was wet with gas- leaking out the throttle plate shaft opening.
Dave
Well, my time went so quickly,
I went lickety-splitly
Out to my ol' 55.
As I pulled away slowly,
Feelin' so holy,
God knows, I was feelin' alive..... Tom Waits, Ol' 55
