1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | just bought some nice carryall rear doors -thanks"larry 59" but they need the door rubber around them ! what would you guys recommend i buy ? what brand ?cant seem to find a "nos " set !!!! HELP HELP HELP !! mike | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Steele Rubber has a correct molded repro of the barn door rubber for the TF series, a bit spendy but perfect - if it's not listed on the website give them a call, they do have it Bill | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Steele Rubber is high dollar but perfect, speaking from experience! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey Les, the reason Steeles repro of the rubber is perfect is cuz I happened on a set of NOS doors years ago [dealer take-offs] that had good rubber in place, and I sent it to Steele for patterns  they gave me a minor break on 2 sets  but I let them keep the originals for their 'library' anyway .... anyone with a TF that has the barn doors should have those seals  Bill | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | You score another big one, Bill! Thanks for helping us all!
best wishes,
Les | | | | | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | thanks guys for the heads up on the barn door rubbers ! i figured "steele" would have some quality stuff ! i did call believe they are $129.00 ,will order next week,NOW I NEED TO FIND A PTO FOR MY WINCH ,to fit that sm 420 and a posi for the rear /believe its a "eaton " {1/2 ton }is it going to be hard to find ???? thanks mike | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Anyone have experience with the barn door rubber from Truck Stop?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Larry, if it's not from Steele than it's just the side door rubber 'by the foot' that doesn't have the correct [and vital] formed corners and corner clips as seen here ... ask them if it's from Steele Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Mike:
I'm glad you like the doors. They were a pretty sweet set. :-)
Since I sold the barn doors to Mike I need the rubber for the clam shell doors on my 58 Suburban. Anyone know if Steele sells clam shell seals? Or anyone else for that matter?
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it's not in Steeles catalog, call and ask, I know they've reproduced the rubber seal for the glass
Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
As always, you are the man. I'll call them and see what they say.
Larry
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | This thread is a little dated but I thought I'd post a follow up. I was at Classic Parts for the KC Chevy/GMC truck club meeting the other day and picked up some door rubber for my clam shell doors. On closer inspection I found the the perimeter of the upper and lower doors had holes drilled for the rubber seal clips just like the driver/passenger doors. On a hunch I had them give me a front door rubber set and I test fitted it on the clam shell. Fit like a charm. I bought the kit and installed it the next day. It works great. The clam shell doors are slightly smaller in circumference so I had to trim the ends to fit. I put a little weather strip adhesive at the seam and it looks quite nice. It helps out tremendously with rattle/road noise and exhaust fumes.
So, although it is not marketed for the the clam shell doors, the Classic Parts #03-012 "(1955-59) Door Rubber Seals - Clip on - pair" works like a charm.
I assume it would work on barn doors as well.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wrong assumption Larry  the side door rubber can be used on the barn doors but doesn't get the proper seal where the doors meet, Steele rubber has the correct seal for the barn doors that has the correct corners and ends as I linked above, only way to do it right Bill | | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | Well, my Steele barn door kit, along with their sealer, is safe in my shop. I am waiting for a warm day to work outside with a "flammable" liquid to disolve the old adhesive. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
Hooah. Good point. Now that I think about it, the weather stripping doesn't match up all the that great where the upper and lower doors meet in the corners.
When I disassemble the doors for eventual painting I'll contact Steele to see if they have the correct rubber. It's good enough for now, but as you say "not the best way to do it right."
Larry
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | I found a use for the leftover weather stripping. I cut it into pieces and wedged it in between the roof arches and the roof. Without a headliner in the back the roof would slap up and down at highway speed. Very annoying. Now there is no more noise.
Larry
