1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
Almost done with '51 chevy truck but I am confused with the proper set up of the horn contact plate, button and the resene or not of a spring.
On the shop manual I saw what looks like a spring on the column....but can't seem to find a replacement at any local shop...do I need one ( I saw one at chevs of the 40s for 41-46)
Do I just set the steering wheel, the horn contact and the contact plate secured with the nut anf cap it off with the horn button?
Any help Thx,
...bearing mast...
...spring...
...retainer washer...
...wheel...
...contact...
...plate...
...washer...
...nut...
...pic...
Maybe you can find a similar spring at the autoparts or hardware store.
Originally Posted by DADS50
...bearing mast...
...spring...
...wheel...
...contact...
...plate...
...washer...
...nut...
...pic...
Awesome! Thank you so much I found eveything but the retainer washer that goes between the spring and wheel...I mounted everything and all seems to work find without it...any idea what the retainer washer does?
I don't know, maybe it keep the spring from digging into the wheel?
I think you'll be OK with out it.
Moderated by  ndkid275, Phak1
