7 members (Buckeye998, Gray_Ghost, Phak1, 1955 1 Series, Otto Skorzeny, SmalltownTRKGuy, Pre '68 Dave),
140
Mod | | | Forums66 Topics128,164 Posts1,056,983 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | Stock 1949 3600. I would like to make it more road worthy. The stock gearing is not going to work for me.
I would also like to lower it as well.
Any advice? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | An overdeive transmission is a good idea for more speed. I bet it's roadworthy as it is if in good shape.
Grigg | | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | Are they readily available?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A T5 is the easy option but its not a 3/4 ton truck transmission... could work if you don't haul stuff often. An NV4500 is a stout enough transmission, more expensive and a little more work to swap.
Both will turn up in searches here.
Grigg | | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | OK thanks. I do not plan on using it like a 3/4 ton truck so the T5 will work just fine.
