1 members (dt235sd), 307 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
Stock 1949 3600. I would like to make it more road worthy. The stock gearing is not going to work for me.
I would also like to lower it as well.
Any advice?
Click the link to see my truck.
http://smu.gs/OuBwfv
An overdeive transmission is a good idea for more speed.
I bet it's roadworthy as it is if in good shape.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Are they readily available?
A T5 is the easy option but its not a 3/4 ton truck transmission... could work if you don't haul stuff often.
An NV4500 is a stout enough transmission, more expensive and a little more work to swap.
Both will turn up in searches here.
Grigg
---All pictures---
OK thanks. I do not plan on using it like a 3/4 ton truck so the T5 will work just fine.
