1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | when i turn on the key it goes to full. i took the float out of the tank its not broken or stuck .maybe a short in the wires ? bad gauge? ignition? One more question the variable switch under dash has a light bulb missing (switch is for the heater).does any one know the number of that bulb it is tiny like a flash light bulb. thanks for all your help. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I believe that you have a '52. The 1952 Operator's Manual calls for #55 six-volt bulbs in the instrument cluster. Use #57 if your electrical system has been converted to twelve volts. Gas Gauge Info from Fifth Avenue Antique Auto Parts: "If dash gauge reads, FULL when tank is known to be only half full the wiring between the tank or the sender is bad. Ground the gas tank sender terminal using a jumper wire, if the dash gauge still shows full there is bad wiring between the dash gauge and the tank sender. If the dash gauge goes to empty, the gas tank sender is defective."> 1952 Operator's Manual - full> Bulb Chart - 1952 Operator's Manual> Gas Gauge Problems - Fifth Avenue > More Gas Gauge Info - Chevytrucks(dot)org
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | thanks, later today i will get right to it . dammmmmm doctors visit first. | | | | | Joined: May 2012 Posts: 18 New Guy | | New Guy Joined: May 2012 Posts: 18 | Related Question: When you switch to 12 volts, does anything need to be done to the sending unit to have the gauge read correctly? Thanx in advacne for any info! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey Hamber - the sender don't know from voltage, it's just resistance [30 ohms originally], but 12V will fry your 6V gauge, it'll need a dropping [Runtz] resistor or a different gauge, which would also need to be compatible with the 30 ohm sender
Bill | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Hamber, Here is another good source for info on the gas gauge. http://www.chevytrucks.org/tech/gasgauge.htmGood luck, Harold
Harold Is a restoration ever finished? | | |
