3 members (Lonnie, 3B, Leo), 72 guests, and 4 robots.
Topics128,187
Posts1,057,316
Members48,468
b10
Offline
when i turn on the key it goes to full. i took the float out of the tank its not broken or stuck .maybe a short in the wires ? bad gauge? ignition? One more question the variable switch under dash has a light bulb missing (switch is for the heater).does any one know the number of that bulb it is tiny like a flash light bulb. thanks for all your help.
I believe that you have a '52.
The 1952 Operator's Manual calls for #55 six-volt bulbs in the instrument cluster. Use #57 if your electrical system has been converted to twelve volts.
Gas Gauge Info from Fifth Avenue Antique Auto Parts:
"If dash gauge reads, FULL when tank is known to be only half full the wiring between the tank or the sender is bad. Ground the gas tank sender terminal using a jumper wire, if the dash gauge still shows full there is bad wiring between the dash gauge and the tank sender. If the dash gauge goes to empty, the gas tank sender is defective."
> 1952 Operator's Manual - full
> Bulb Chart - 1952 Operator's Manual
> Gas Gauge Problems - Fifth Avenue
> More Gas Gauge Info - Chevytrucks(dot)org
- Lonnie
My '54 3104
b10
Offline
thanks, later today i will get right to it . dammmmmm doctors visit first.
Related Question: When you switch to 12 volts, does anything need to be done to the sending unit to have the gauge read correctly? Thanx in advacne for any info!
hey Hamber - the sender don't know from voltage, it's just resistance [30 ohms originally], but 12V will fry your 6V gauge, it'll need a dropping [Runtz] resistor or a different gauge, which would also need to be compatible with the 30 ohm sender
Hamber,
Here is another good source for info on the gas gauge.
http://www.chevytrucks.org/tech/gasgauge.htm
Good luck,
Harold
Harold
