Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 158 guests, and 10 robots.
Topics128,283
Posts1,058,519
Members48,490
Just curious to know whether anyone has done this. I see that Cletis has posted a how-to on a 56 with a wide rear window. My truck has the small rear window and a different layout with the B-pillar. I'm not sure how to get behind the sheet metal without cutting a pretty good size hole for access.
1956 Chevy 3200
I welded a 3/8 inch rod to the nut and washer and pushed it up to the hole and screwed bolt in and left the rod in, you can't tell it is behind the pillar(the rod). There is a picture in the link at my signature.
Larry
So you didn't weld a plate to the back side of the sheet metal? Did you have any trouble with the rod rattling around inside?
1956 Chevy 3200
Joe - tack weld a nut to a plate or large fender washer, epoxy glue a thin stick to the plate, do as Larry suggests, once the bolt is tightened, break the stick loose and pull it out
OK, thanks. I'll give that a shot.
1956 Chevy 3200
Mine does not rattle but I believe red58's idea is the best. I used the large fender type washer also.
Larry
where do i find the post by cletis for the 56 big window??
Moderated by  ndkid275, Phak1
