2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#875705 08/18/2012 7:51 AM
Do I just need to take off the panel and adjust something?
more like reconnect a lever or latch or unbend something. not much in there to adjust if its like the 55-59 series
The long rod from the handle to the latch is bent or disconnected.
lube all the pivot points well as you go.
best wishes,
Les
Thanks. I'll poke around
Thanks. I'll get inside and check it out.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Awesome! Thanks!
