0 members (),
136
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88200 09/04/2004 6:12 AM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Several weeks ago I posted this problem with my 49. Chevy Duty wiring harness, 12 volt with alternator. The only way to shut the engine off was to disconnect the battery.
With everyone's help, the ignition switch was the suspect so I took it apart, cleaned, etc. and it bench tested ok.
I started it up tonight and same thing, except now even disconnecting the battery doesn't shut it off (I guess it would eventually) I shut it down by pulling the coil wire.
I'm going to swear (until proven wrong) that all of the wiring is correct.
I read an archived post where someone had the same problem with a 59 and solved it by installing a 12 volt warning light (resistance???) in the line running from the ignition switch to the alternator.
I'm open to suggestions, I'm in over my head on this one.
Thanks, | | |
#88201 09/04/2004 7:45 AM | Joined: Jan 2004 Posts: 32 Junior Member | | Junior Member Joined: Jan 2004 Posts: 32 | You need to check the wire going to the + side of the coil, if this wire has voltage with the key off you need to find where the voltage is coming from,the coil should not have power with the key off. If you disconnect the battery with the engine running the engine will continue to run as long as the alternator is charging, but doing this can damage the alternator. | | |
#88202 09/04/2004 2:40 PM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Thanks. I have two wires going to the (+) on the coil.
1.Line from ignition switch with the ballast resistor. This one seems to be ok.
2.Line from side terminal of starter switch. This one is hot with or without the ignition on. I guess that makes the starter switch the newest suspect. And it is a new switch. I'll have to take it off and have a look.
Am I correct that the side terminal should only be hot when the switch is depressed? | | |
#88203 09/04/2004 10:19 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you are using a GM alt. with internal regulator you must have resistance or a diode in the signal wire from the ignition switch. I use a dash light with plastic socket & 2 wires. That also gives you a warning light. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#88204 09/05/2004 6:41 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | About your two wires going to the + side of the coil: 1. wire from ballast resistor is correct. 2. this wire should go to the ballast resistor bypass terminal on the starter motor. If there is no bypass on your starter motor, you can wire it to the starter switch. However it should only be hot when the starter switch is activated. You said it is hot all the time? That's not good for your battery or points.
Try this: disconnect the second wire on the coil so the only wire to the + on the coil is the one from the ballast resistor. Start the engine. If you can shut it off normally, you have ruled out the alternator as the problem.
Gord 1954 1/2 ton 235 4 speed
#88205 09/08/2004 6:33 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Does your alternator have a DA plug (two wires) on it? If so, try disconnecting the plug and shutting off the engine. That will rule out the alternator if it shuts off with the DA plug disconnected. The sense lead of the voltage regulator is supposed to be connected to the battery but the indicator is supposed to connect to a switched source. If they are backwards the alternator will power the ignition through the regulator and it won't shut off, although if there is a bulb or diode it should prevent that. Also, some ignition switches (the one on my '50) have two accessory terminals that are isolated, so you can connect the accessories and alternator to one and the ignition to the other and prevent that problem.
#88206 09/08/2004 1:23 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I didn't have this problem ... but my engine was "running on" just a tad when I shut it off, until I installed a diode on the wire that goes to the alternator from the ignition: [img] http://www.alanhorvath.com/54chevy/chevypics/wiring_1.jpg[/img]
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#88207 09/08/2004 2:11 PM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | The starter switch appears to be the guilty party. I disconnected the wire going from the side terminal to the coil and everything works ok. The starter switch is new. I haven't had a chance to pull it out and see what the problem is.
Thanks everyone. | | |
