4 members (kades51, wilbur53, UtahYork, Ridgeback), 72 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
looking for the replacement ends that butt up to wheel cylinders. mine have lost their depth, and will no longer adjust the wheel cylinder. if someone has 1 sitting around, good. but if you have four of the complete shafts, wonderful.
olhoke - you need to make a parts request in the Parts Wanted Swap Forum - and specify the year [43?] .... you also need to clarify just what you're looking for, there is no "pinion shaft" in the brakes, and nothing that "adjusts the wheel cylinder" ... maybe you need the cylinder to shoe rod?
Bill, those parts exist. They actually are called pinions. They are a small wheel with nubs on it that when turned from a bolt head on the backing plate, adjust the wheel cylinder caps and hence the brake shoe to drum contact.
I swear I've seen a vendor carrying them in the past...
Jeff
My 1953 Chevrolet
1947.1 Gallery
Almost forgot, they were used on huck brakes, rears only.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I have often wondered if one could remove them and cut slots to adjust them like the front ones. I really like the rear adjusters, it is just that when they are gone it is a problem.
1951 1 Ton Completed
thanks guys. if i find some, will let you know. and guess i got told. for the record, the truck is a 48 pickup, serial number 5FSJ3502. was built in october, 48, london, ontario. i sure wish you guys could help with my stude 2r10 early. thanks for all your help.
The backing plates complete with adjusters, come up on Ebay all the time.
I don't think he's looking for the backing plates, I think he is looking for the piece that fits over the wheel cylinder. Correct?
No, he is looking for the adjusters that are mount through the backing plate, have a bolt head on the outside and a gear on the inside. He could buy the endcaps easily even if it meant new cylinders.
On my 48 the adjusters can't be removed. I had one that had broken off and welded it back on to the stud. New cylinders are $120/each. If OP just wants the endcaps, I've got them..... Send me a PM.
Moderated by  Dusty53
