| | | Forums66 Topics128,260 Posts1,058,321 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | I have busted nearly every bolt that holds the fender to the fender well. No big deal as fender well sheet metal is all rotted and needs replaced anyway.(Like everywhere else on this truck!) I was going to use weldnuts from MC for the fender to bolt to. Just wondered if somebody used a newer better, or different method. I was thinking of going the easy route and using self tappers but didn't think that would be very strong. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | question for the Paint & Body forum .... best to use some fixed threaded item like original
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think this is a recent discussion about those bolts/washers? I'll leave this post here, for people with more first-hand experience with these captive nuts to read and offer advice. I had someone weld-in the appropriate captive nuts. | | |
