7 members (2-Ton, RoadsScholar, Wayne67vert, Peggy M, moparguy, ESum, 1 invisible), 70 guests, and 1 robot.
Topics128,211
Posts1,057,467
Members48,471
Took the valve cover off my '37 truck to clean it up and paint. Lying on top of the rocker arms is a "pad" running the full length of the assembly. Is this normal? The engine was running fine. Should I leave this in or replace it? Where can I find anew one.?
CAB
a valve train silencer. take it out and run the truck. see what the difference is then decide what to do.
My understanding is that they used an actual pad with the old four cylinder engine that ended in 1928. I have heard people mention about putting one on one of these sixes so I am wondering if some actually did so. The earlier pads were used to keep the shaft oiled.
1951 1 Ton Completed
1 Offline
I saw those being sold last year when I was in Cortez, Co at an Auto Parts store. The containers looked very fresh and they may still be a production item available on special order.
Normbc9
