5 members (60steve, Alex52, Gdads51, 2 invisible),
76
0
Mod | | | Forums66 Topics128,212 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 29 New Guy | | New Guy Joined: Aug 2000 Posts: 29 | Took the valve cover off my '37 truck to clean it up and paint. Lying on top of the rocker arms is a "pad" running the full length of the assembly. Is this normal? The engine was running fine. Should I leave this in or replace it? Where can I find anew one.? Thanks,
CAB | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | a valve train silencer. take it out and run the truck. see what the difference is then decide what to do. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My understanding is that they used an actual pad with the old four cylinder engine that ended in 1928. I have heard people mention about putting one on one of these sixes so I am wondering if some actually did so. The earlier pads were used to keep the shaft oiled. | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I saw those being sold last year when I was in Cortez, Co at an Auto Parts store. The containers looked very fresh and they may still be a production item available on special order. Normbc9 | | |
